{ "__default": { "session": { "counter": 4, "timer": { "start": 1721155427, "last": 1721155437, "now": 1721155437 }, "token": "FiFFAI2nc7vDhrZcS5AeVUeFUV95ZYMX" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/3/394", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/viewtopic.php?f=3&t=394", "phpbb_user": false } }
WHERE `session_id` = X'3763333932396438663233363365363330383665623662323862343430323930'
Sending data | 0.29 ms |
WHERE time + '86400'<'1721155437'
SET `params` = '{\"mediaversion\":\"614501fe98b41d0b1d073244434da93d\"}'
Sending data | 1.24 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/3/394'
1 × UPDATE `dm4t9_extensions`
1 ×
