Noel du Club
Noel du Club
ATTENTION Changement de date : Étant indisponibles le 14 décembre, nous avançons le Noël du club au 7 décembre. Nous espérons vous y retrouver nombreux.
Message par Colette Haederli » ven. 8 nov. 2019 14:44
{ "__default": { "session": { "counter": 2, "timer": { "start": 1721137454, "last": 1721137454, "now": 1721137454 }, "token": "aRS4wNJYgbZullkoub4nk45yuseDbhn8" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/3/901", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/viewtopic.php?f=3&t=901", "phpbb_user": false } }
WHERE `session_id` = X'6630316137623635326232386334643365323361646539643662376261613466'
executing | 0.04 ms |
end | 0.05 ms |
WHERE time + '86400'<'1721137454'
SET `params` = '{\"mediaversion\":\"35f91c3168fbeac3f42f0054b646bc12\"}'
starting | 0.17 ms |
statistics | 0.34 ms |
Sending data | 1.67 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/3/901'
1 × UPDATE `dm4t9_extensions`
1 ×
