deux C1 à donner
deux C1 à donner
Un C1 Cascade en parfait état et un C1 slalom Groin en parfait état + pagaie
Contacter : knopfelw@bluewin.ch
Message par WKnopfel » mer. 25 janv. 2023 11:40
{ "__default": { "session": { "counter": 2, "timer": { "start": 1726586127, "last": 1726586127, "now": 1726586127 }, "token": "MpmKnVAC6gEn6DB7yQO60YRhoWqmOKY3" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/4/1184", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/viewtopic.php?f=4&t=1184", "phpbb_user": false } }
WHERE `session_id` = X'6236663035643034333163366232333430366438643964383833663835653930'
1 | SIMPLE | dm4t9_jfbconnect_config | ALL | NULL | INDEX N'A PU ÊTRE UTILISÉ | NULL | NULL | 101 | 100.00 | NULL |
Sending data | 0.44 ms |
WHERE time + '86400'<'1726586127'
SET `params` = '{\"mediaversion\":\"f41927b2b19f5964a65cec1c310f1d5e\"}'
end | 5.49 ms |
query end | 0.47 ms |
1 | SIMPLE | dm4t9_assets | ALL | idx_asset_name | INDEX N'A PU ÊTRE UTILISÉ | NULL | NULL | 414 | 9.90 | Using where |
Sending data | 1.51 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/4/1184'
1 × UPDATE `dm4t9_extensions`
1 ×
