Canoë à donner
Canoë à donner
A donner: canoe biplace démontable. Tél. 022 798.85.84 ou 079 529 74 99 (Constantin Manoil). Si personne n'est intéessé, à la fin du mois je m'en débarasse.
{ "__default": { "session": { "counter": 2, "timer": { "start": 1721148883, "last": 1721148883, "now": 1721148884 }, "token": "eeQMqtr9pikyERm8oca7YGIXDkQNHx6Q" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/4/122", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/viewtopic.php?f=4&t=122", "phpbb_user": false } }
WHERE `session_id` = X'3436623537636339303934333866333435323932336435653137636166623663'
WHERE time + '86400'<'1721148884'
SET `params` = '{\"mediaversion\":\"e30128b48838977f561665e704c1dd00\"}'
Sending data | 1.28 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/4/122'
1 × UPDATE `dm4t9_extensions`
1 ×
