{ "__default": { "session": { "counter": 3, "timer": { "start": 1725173848, "last": 1725173848, "now": 1725173858 }, "token": "Hq4vsmUbhhBd2AHXubf5OURuhnFGjgct" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/post/quote?f=3&p=1433", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/posting.php?f=3&p=1433&mode=quote", "phpbb_user": false } }
WHERE `session_id` = X'6134316361633964653439303338613563356232383563623639626131383764'
WHERE time + '86400'<'1725173858'
SET `params` = '{\"mediaversion\":\"2b96c4da5d118edfb7b9d7c7c0cd2128\"}'
end | 0.05 ms |
SELECT *
FROM dm4t9_languages
WHERE published=1
ORDER BY ordering ASC
Opening tables | 0.41 ms |
Creating sort index | 0.06 ms |
Sending data | 1.11 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/post/quote?f=3&p=1433'
1 × SELECT *
1 × UPDATE `dm4t9_extensions`
1 ×
