{ "__default": { "session": { "counter": 4, "timer": { "start": 1721127665, "last": 1721127674, "now": 1721127685 }, "token": "UXH7sn8CET8I4bIKMhbvefEDi9iH0cnt" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/post/quote?f=3&p=3286", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/posting.php?f=3&p=3286&mode=quote", "phpbb_user": false } }
WHERE `session_id` = X'3538623335306361333930636561366636316366353835393136316538393735'
FROM dm4t9_extensions
WHERE enabled = 1
AND type = 'plugin'
AND state IN (0,1)
AND access IN (1,3)
ORDER BY ordering
Creating sort index | 0.72 ms |
Sending data | 0.21 ms |
WHERE time + '86400'<'1721127685'
SET `params` = '{\"mediaversion\":\"116ecdd3e7552eaa6fda74bc0485ca21\"}'
query end | 0.22 ms |
Sending data | 1.04 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/post/quote?f=3&p=3286'
1 × UPDATE `dm4t9_extensions`
1 ×
