{ "__default": { "session": { "counter": 2, "timer": { "start": 1723679511, "last": 1723679511, "now": 1723679521 }, "token": "pq2tIxV18DZcdpqVPdXZlgNVPOfK1wkD" }, "registry": {}, "user": { "id": 0, "name": null, "username": null, "email": null, "password": null, "password_clear": "", "block": null, "sendEmail": 0, "registerDate": null, "lastvisitDate": null, "activation": null, "params": null, "groups": [], "guest": 1, "lastResetTime": null, "resetCount": null, "requireReset": null, "aid": 0 }, "phpbb_page": "https://canoe-club-geneve.ch/forums/post/quote?f=3&p=3634", "phpbb_page_real": "https://canoe-club-geneve.ch/forumphpBB_3/posting.php?f=3&p=3634&mode=quote", "phpbb_user": false } }
WHERE `session_id` = X'6435623666643038323765653462343466373766336331393361393637353066'
WHERE `type` = 'component'
AND `state` = 0
AND `enabled` = 1
Sending data | 0.43 ms |
executing | 0.05 ms |
WHERE time + '86400'<'1723679521'
SET `params` = '{\"mediaversion\":\"0351a92281fedb8f65b6b1e9cbe082bf\"}'
end | 5.38 ms |
query end | 0.41 ms |
Sending data | 0.90 ms |
WHERE url = 'https://canoe-club-geneve.ch/forums/post/quote?f=3&p=3634'
1 × UPDATE `dm4t9_extensions`
1 ×
